Delete a cluster peer
DELETE /cluster/peers/{uuid}
Introduced In: 9.6
Deletes a cluster peer.
uuid  |
string  |
path  |
True  |
Cluster peer relationship UUID  |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
4653079  |
Unable to delete peer relationship.  |
4663070  |
Unable to delete cluster peer relationship due to an ongoing Vserver migration.  |
| Name | Type | Description |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
