REST API reference
Delete a cluster peer
Removes a cluster peer to discontinue its association with other clusters, typically as part of decommissioning or reconfiguration processes.
HTTP method and endpoint
DELETE /cluster/peers/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Deletes a cluster peer.
uuid
string
path
True
Cluster peer relationship UUID
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
4653079
Unable to delete peer relationship.
4663070
Unable to delete cluster peer relationship due to an ongoing Vserver migration.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
