REST API reference
Delete a software package from the cluster
Deletes a software package from the cluster when it is no longer needed or if you want to free up space.
HTTP method and endpoint
DELETE /cluster/software/packages/{version}
Introduced in
ONTAP 9.6
Usage notes
The delete operation fails if the package is currently installed.
  • cluster image package delete
version
string
path
True
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 202, Accepted
Status: Default
ONTAP error response codes
Error codes Description
10551315
Package store is empty
10551322
Error in retrieving package cleanup status
10551323
Error in cleaning up package information on a node
10551324
Error in cleaning up package information on multiple nodes
10551325
Package does not exist on the system
10551326
Error in deleting older package cleanup tasks. Clean up images from the store and retry
10551346
Package delete failed since a validation is in progress
10551347
Package delete failed since an update is in progress
10551367
A package synchronization is in progress
10551388
Package delete operation timed out
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
