REST API reference
Delete a software package from the cluster
Deletes a software package from the cluster, removing it from the available options for installation.
HTTP method and endpoint
DELETE /cluster/software/packages/{version}
Introduced in
ONTAP 9.6
Usage notes
The delete operation fails if the package is currently installed.
  • cluster image package delete
version
string
path
True
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Name Type Description
job
job_link
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
10551315
The repository does not contain any packages.
10551322
An internal error occurred while retrieving the package cleanup status.
10551323
An internal error occurred while removing the package information on a node.
10551324
An internal error occurred while removing the package information on multiple nodes.
10551325
The required package could not be found in the repository.
10551326
An error occurred while deleting older package cleanup tasks.
10551346
A validation is in progress, retry command after it is completed.
10551367
The repository is busy, retry the operation later.
10551388
The package delete operation timed out.
10551892
Package delete failed due to an unhealthy node. Restore the node to a healthy state, then retry the operation.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
