Delete a software package from the cluster
Deletes a software package from the cluster when you need to remove an unused package.
HTTP method and endpoint
DELETE /cluster/software/packages/{version}
Introduced in
ONTAP 9.6
Usage notes
The delete operation fails if the package is currently installed.
Related ONTAP commands
cluster image package delete
Learn more
version |
string |
path |
True |
return_timeout |
integer |
query |
False |
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
10551315 |
The repository does not contain any packages. |
10551322 |
An internal error occurred while retrieving the package cleanup status. |
10551323 |
An internal error occurred while removing the package information on a node. |
10551324 |
An internal error occurred while removing the package information on multiple nodes. |
10551325 |
The required package could not be found in the repository. |
10551326 |
An error occurred while deleting older package cleanup tasks. |
10551346 |
A validation is in progress, retry command after it is completed. |
10551367 |
The repository is busy, retry the operation later. |
10551388 |
The package delete operation timed out. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
