Delete an S3 audit configuration
Deletes an S3 audit configuration when you need to remove audit settings that are no longer required for your S3 operations.
HTTP method and endpoint
DELETE /protocols/audit/{svm.uuid}/object-store
Introduced in
ONTAP 9.10
Related ONTAP commands
vserver object-store-server audit disable -
vserver object-store-server audit delete
Learn more
force |
boolean |
query |
False |
Indicates whether a force deletion of the audit configuration is enabled. |
return_timeout |
integer |
query |
False |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
140902420 |
Failed to delete audit configuration for the SVM. |
140902421 |
Failed to delete audit configuration for the SVM because audit is enabled for the SVM. |
140902422 |
Failed to delete audit configuration for the SVM because final conolidation is in progress. Wait a few mintues, and try the operation again. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
