REST API reference
Delete an S3 audit configuration
Deletes an S3 audit configuration when you need to remove audit settings for object store operations.
HTTP method and endpoint
DELETE /protocols/audit/{svm.uuid}/object-store
Introduced in
ONTAP 9.10
  • vserver object-store-server audit disable
  • vserver object-store-server audit delete
force
boolean
query
False
Indicates whether a force deletion of the audit configuration is enabled.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
svm.uuid
string
path
True
Status: 200, Ok
Name Type Description
job
job_link
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
140902420
Failed to delete audit configuration for the SVM.
140902421
Failed to delete audit configuration for the SVM because audit is enabled for the SVM.
140902422
Failed to delete audit configuration for the SVM because final consolidation is in progress. Wait a few minutes, and try the operation again.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
