Delete an S3 audit configuration
Deletes an S3 audit configuration to remove monitoring settings for object store operations.
HTTP method and endpoint
DELETE /protocols/audit/{svm.uuid}/object-store
Introduced in
ONTAP 9.10
Related ONTAP commands
vserver object-store-server audit disable -
vserver object-store-server audit delete
Learn more
force |
boolean |
query |
False |
Indicates whether a force deletion of the audit configuration is enabled. |
return_timeout |
integer |
query |
False |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
140902420 |
Failed to delete audit configuration for the SVM. |
140902421 |
Failed to delete audit configuration for the SVM because audit is enabled for the SVM. |
140902422 |
Failed to delete audit configuration for the SVM because final conolidation is in progress. Wait a few mintues, and try the operation again. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
