Delete an FC protocol service
Deletes an FC protocol service that is no longer needed, ensuring it is disabled before removal.
HTTP method and endpoint
DELETE /protocols/san/fcp/services/{svm.uuid}
Introduced in
ONTAP 9.6
Usage notes
An FC Protocol service must be disabled before it can be deleted.
Related ONTAP commands
vserver fcp delete
Learn more
svm.uuid |
string |
path |
True |
The unique identifier of the SVM for which to delete the FC Protocol service. |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2621462 |
An SVM with the specified UUID does not exist. |
5373960 |
The Fibre Channel Protocol service cannot be removed while it is enabled. |
5374083 |
There is no Fibre Channel Protocol service for the specified SVM. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
