REST API reference
Delete an FC protocol service
Deletes an FC Protocol service when you no longer need it for your storage network configuration. Ensure the service is disabled before proceeding with the deletion.
HTTP method and endpoint
DELETE /protocols/san/fcp/services/{svm.uuid}
Introduced in
ONTAP 9.6
Usage notes
An FC Protocol service must be disabled before it can be deleted.
  • vserver fcp delete
svm.uuid
string
path
True
The unique identifier of the SVM for which to delete the FC Protocol service.
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
2621462
An SVM with the specified UUID does not exist.
5373960
The Fibre Channel Protocol service cannot be removed while it is enabled.
5374083
There is no Fibre Channel Protocol service for the specified SVM.
5376452
Service POST and DELETE are not supported on ASA r2.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
