Delete an FC protocol service
Deletes an FC protocol service when it is no longer needed in your storage environment. Make sure the service is disabled before performing this action.
HTTP method and endpoint
DELETE /protocols/san/fcp/services/{svm.uuid}
Introduced in
ONTAP 9.6
Usage notes
An FC Protocol service must be disabled before it can be deleted.
Related ONTAP commands
vserver fcp delete
Learn more
svm.uuid |
string |
path |
True |
The unique identifier of the SVM for which to delete the FC Protocol service. |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2621462 |
An SVM with the specified UUID does not exist. |
5373960 |
The Fibre Channel Protocol service cannot be removed while it is enabled. |
5374083 |
There is no Fibre Channel Protocol service for the specified SVM. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
