REST API reference
Delete a CA certificate with the specified UUID from IPsec
Deletes a CA certificate from IPsec, effectively removing it from the certificate list used for secure communications.
HTTP method and endpoint
DELETE /security/ipsec/ca-certificates/{certificate.uuid}
Introduced in
ONTAP 9.10
Usage notes
Deletes the IPsec CA certificate with the specified UUID from IPsec.
  • security ipsec ca-certificate remove
certificate.uuid
string
path
True
UUID of the CA certificate to be deleted from IPsec.
Status: 200, Ok
Status: Default, Error
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
