Delete a CA certificate with the specified UUID from IPsec
Deletes a CA certificate from IPsec using its unique identifier when you need to remove it from the system's security configuration.
HTTP method and endpoint
DELETE /security/ipsec/ca-certificates/{certificate.uuid}
Introduced in
ONTAP 9.10
Usage notes
Deletes the IPsec CA certificate with the specified UUID from IPsec.
Related ONTAP commands
security ipsec ca-certificate remove
certificate.uuid |
string |
path |
True |
UUID of the CA certificate to be deleted from IPsec. |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
66257298 |
CA certificate is not installed for IPsec. |
66257303 |
The CA certificate cannot be removed from IPsec because it is not installed. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
