REST API reference
Delete a CA certificate with the specified UUID from IPsec
Deletes a CA certificate from IPsec using its unique identifier when you need to remove it from the system's security configuration.
HTTP method and endpoint
DELETE /security/ipsec/ca-certificates/{certificate.uuid}
Introduced in
ONTAP 9.10
Usage notes
Deletes the IPsec CA certificate with the specified UUID from IPsec.
  • security ipsec ca-certificate remove
certificate.uuid
string
path
True
UUID of the CA certificate to be deleted from IPsec.
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
66257298
CA certificate is not installed for IPsec.
66257303
The CA certificate cannot be removed from IPsec because it is not installed.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
