Delete an IPsec policy
Deletes an IPsec policy to remove configuration settings associated with secure network communications. Use this when you need to clear outdated or unnecessary policies from the system.
HTTP method and endpoint
DELETE /security/ipsec/policies/{uuid}
Introduced in
ONTAP 9.8
Usage notes
Deletes a specific IPsec policy.
Related ONTAP commands
security ipsec policy delete
uuid |
string |
path |
True |
IPsec policy UUID |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
66257096 |
Internal error. Failed to purge connections associated with the IPsec policy. |
66257116 |
IPsec policy with the specified UUID was not found. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
