REST API reference
Delete an IPsec policy
Deletes an IPsec policy to remove its configuration from the system, typically when it's no longer needed for network security settings.
HTTP method and endpoint
DELETE /security/ipsec/policies/{uuid}
Introduced in
ONTAP 9.8
Usage notes
Deletes a specific IPsec policy.
  • security ipsec policy delete
uuid
string
path
True
IPsec policy UUID
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
66257096
Internal error. Failed to purge connections associated with the IPsec policy.
66257116
IPsec policy with the specified UUID was not found.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
