REST API reference
Delete an IPsec policy
Deletes a specific IPsec policy when you need to remove an existing policy configuration that is no longer required.
HTTP method and endpoint
DELETE /security/ipsec/policies/{uuid}
Introduced in
ONTAP 9.8
  • security ipsec policy delete
uuid
string
path
True
IPsec policy UUID
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
66257096
Internal error. Failed to purge connections associated with the IPsec policy.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
