REST API reference
Removes the file from the monitored file list
Removes a file from the monitored file list to stop tracking its changes and activities.
HTTP method and endpoint
DELETE /storage/monitored-files/{uuid}
Introduced in
ONTAP 9.8
Usage notes
Removes the file from the list of monitored files.
uuid
string
path
True
return_records
boolean
query
False
  • Default value:
Status: 200, Ok
Status: Default, Error
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
