REST API reference
Removes the file from the monitored file list
Removes a file from the monitored list when it's no longer needed for tracking or analysis. This action helps manage the list by eliminating files that are no longer relevant.
HTTP method and endpoint
DELETE /storage/monitored-files/{uuid}
Introduced in
ONTAP 9.8
Usage notes
Removes the file from the list of monitored files.
uuid
string
path
True
Status: 200, Ok
Status: Default, Error
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
