REST API reference
Delete an event filter
Deletes an event filter to remove specific criteria used for event notifications. Use this operation to manage and refine your event monitoring setup.
HTTP method and endpoint
DELETE /support/ems/filters/{name}
Introduced in
ONTAP 9.6
  • event filter delete
name
string
path
True
Filter name
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
983113
Default filters cannot be modified or removed
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
