Delete an event filter
Deletes an event filter to remove specific criteria from your event monitoring setup. This action helps you manage and refine the events you track, ensuring your monitoring aligns with current priorities.
HTTP method and endpoint
DELETE /support/ems/filters/{name}
Introduced in
ONTAP 9.6
Related ONTAP commands
event filter delete
name |
string |
path |
True |
Filter name |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
983113 |
Default filters cannot be modified or removed |
983124 |
Filter is being referenced by a destination |
983204 |
Filter is being used for role-based operations |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
