Delete an event filter
Deletes an event filter to remove it from your system's configuration, typically when it is no longer needed or requires replacement.
HTTP method and endpoint
DELETE /support/ems/filters/{name}
Introduced in
ONTAP 9.6
Related ONTAP commands
event filter delete
name |
string |
path |
True |
Filter name |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
983113 |
Default filters cannot be modified or removed |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
