REST API reference
Delete SVM migrations
Deletes SVM migrations to remove completed or aborted migration tasks from your ONTAP system. This is typically used to clean up after migration activities or when a migration is no longer needed.
HTTP method and endpoint
DELETE /svm/migrations/{uuid}
Introduced in
ONTAP 9.10
Usage notes
Deletes the SVM migration.
  • vserver migrate abort
uuid
string
path
True
SVM migration UUID.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
13172783
Migrate RDB lookup failed
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
