Delete SVM migrations
Deletes an SVM migration when you no longer need to maintain the migration state or wish to cancel the process.
HTTP method and endpoint
DELETE /svm/migrations/{uuid}
Introduced in
ONTAP 9.10
Related ONTAP commands
vserver migrate abort
uuid |
string |
path |
True |
SVM migration UUID. |
return_timeout |
integer |
query |
False |
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
13172783 |
Migrate RDB lookup failed |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
