REST API reference
Delete SVM migrations
Deletes an SVM migration to remove a migration configuration that is no longer needed. This action helps manage your storage resources by clearing obsolete data transfers.
HTTP method and endpoint
DELETE /svm/migrations/{uuid}
Introduced in
ONTAP 9.10
  • vserver migrate abort
uuid
string
path
True
SVM migration UUID.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Name Type Description
job
job_link
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
13172783
Migrate RDB lookup failed
13173738
REST API DELETE method \"/api/svm/migrations\" is only supported on the destination cluster. Issue the REST API DELETE request to the destination cluster.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
