Retrieve license packages
Retrieves a collection of license packages to review the available licenses on your system. This can help you manage and assess the licensing status of your ONTAP environment.
HTTP method and endpoint
GET /cluster/licensing/licenses
Introduced in
ONTAP 9.6
Usage notes
By default, the GET method only returns licensed packages. You must provide the following query "state=unlicensed" to retrieve unlicensed packages. |
Related ONTAP commands
system license show-status -
system license show
state |
string |
query |
False |
Filter by state |
licenses.start_time |
string |
query |
False |
Filter by licenses.start_time |
licenses.installed_license |
string |
query |
False |
Filter by licenses.installed_license
licenses.owner |
string |
query |
False |
Filter by licenses.owner |
licenses.compliance.state |
string |
query |
False |
Filter by licenses.compliance.state |
licenses.serial_number |
string |
query |
False |
Filter by licenses.serial_number |
licenses.evaluation |
boolean |
query |
False |
Filter by licenses.evaluation |
licenses.active |
boolean |
query |
False |
Filter by licenses.active |
licenses.host_id |
string |
query |
False |
Filter by licenses.host_id
licenses.capacity.maximum_size |
integer |
query |
False |
Filter by licenses.capacity.maximum_size |
licenses.capacity.used_size |
integer |
query |
False |
Filter by licenses.capacity.used_size |
licenses.expiry_time |
string |
query |
False |
Filter by licenses.expiry_time |
name |
string |
query |
False |
Filter by name |
scope |
string |
query |
False |
Filter by scope |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[records] |
"next": {
"href": "/api/resourcelink"
"records": [
"licenses": [
"capacity": {
"maximum_size": 0,
"used_size": 0
"compliance": {
"state": "compliant"
"expiry_time": "2019-03-02T19:00:00Z",
"host_id": "456-44-1234",
"installed_license": "Core Bundle",
"owner": "cluster1",
"serial_number": "123456789",
"start_time": "2019-02-02T19:00:00Z"
"name": "NFS",
"scope": "string",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
capacity
maximum_size |
integer |
Licensed capacity size (in bytes) that can be used. |
used_size |
integer |
Capacity that is currently used (in bytes). |
compliance
state |
string |
Compliance state of the license. |
licenses
active |
boolean |
A flag indicating whether the license is currently being enforced. |
capacity |
compliance |
evaluation |
boolean |
A flag indicating whether the license is in evaluation mode. |
expiry_time |
string |
Date and time when the license expires. |
host_id |
string |
A string that associates the license with a node or cluster. |
installed_license |
string |
Name of license that enabled the feature. |
owner |
string |
Cluster, node or license manager that owns the license. |
serial_number |
string |
Serial number of the license. |
start_time |
string |
Date and time when the license starts. |
records
_links |
licenses |
array[licenses] |
Installed licenses of the package. |
name |
string |
Name of the license. |
scope |
string |
Scope of the license. |
state |
string |
Summary state of package based on all installed licenses. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
