Retrieve license packages
GET /cluster/licensing/licenses
Introduced In: 9.6
Retrieves a collection of license packages.
By default, the GET method only returns licensed packages. You must provide the following query "state=unlicensed" to retrieve unlicensed packages. Note: Starting with ONTAP 9.11.1, the GET method no longer returns the Base license record. |
Related ONTAP commands
system license show-status -
system license show
entitlement.risk |
string |
query |
False |
Filter by entitlement.risk
entitlement.action |
string |
query |
False |
Filter by entitlement.action
state |
string |
query |
False |
Filter by state |
scope |
string |
query |
False |
Filter by scope |
description |
string |
query |
False |
Filter by description
name |
string |
query |
False |
Filter by name |
licenses.expiry_time |
string |
query |
False |
Filter by licenses.expiry_time |
licenses.compliance.state |
string |
query |
False |
Filter by licenses.compliance.state |
licenses.serial_number |
string |
query |
False |
Filter by licenses.serial_number |
licenses.shutdown_imminent |
boolean |
query |
False |
Filter by licenses.shutdown_imminent
licenses.capacity.maximum_size |
integer |
query |
False |
Filter by licenses.capacity.maximum_size |
licenses.capacity.used_size |
integer |
query |
False |
Filter by licenses.capacity.used_size |
licenses.installed_license |
string |
query |
False |
Filter by licenses.installed_license
licenses.host_id |
string |
query |
False |
Filter by licenses.host_id
licenses.start_time |
string |
query |
False |
Filter by licenses.start_time |
licenses.active |
boolean |
query |
False |
Filter by licenses.active |
licenses.owner |
string |
query |
False |
Filter by licenses.owner |
licenses.evaluation |
boolean |
query |
False |
Filter by licenses.evaluation |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[records] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"description": "NFS License",
"entitlement": {
"action": "string",
"risk": "string"
"licenses": [
"capacity": {
"maximum_size": 0,
"used_size": 0
"compliance": {
"state": "compliant"
"expiry_time": "2019-03-02 19:00:00 +0000",
"host_id": "456-44-1234",
"installed_license": "Core Bundle",
"owner": "cluster1",
"serial_number": "123456789",
"start_time": "2019-02-02 19:00:00 +0000"
"name": "NFS",
"scope": "string",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
entitlement
action |
string |
Entitlement action to be taken to mitigate the risk |
risk |
string |
Entitlement risk of the package |
capacity
maximum_size |
integer |
Licensed capacity size (in bytes) that can be used. |
used_size |
integer |
Capacity that is currently used (in bytes). |
compliance
state |
string |
Compliance state of the license. |
licenses
active |
boolean |
A flag indicating whether the license is currently being enforced. |
capacity |
compliance |
evaluation |
boolean |
A flag indicating whether the license is in evaluation mode. |
expiry_time |
string |
Date and time when the license expires. |
host_id |
string |
A string that associates the license with a node or cluster. |
installed_license |
string |
Name of license that enabled the feature. |
owner |
string |
Cluster, node or license manager that owns the license. |
serial_number |
string |
Serial number of the license. |
shutdown_imminent |
boolean |
A flag indicating whether the Cloud ONTAP system is going to shutdown as the Cloud platform license has already expired.
start_time |
string |
Date and time when the license starts. |
records
_links |
description |
string |
License description |
entitlement |
licenses |
array[licenses] |
Installed licenses of the package. |
name |
string |
Name of the license. |
scope |
string |
Scope of the license. |
state |
string |
Summary state of package based on all installed licenses. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
