Retrieve license packages
GET /cluster/licensing/licenses
Introduced In: 9.6
Retrieves a collection of license packages.
By default, the GET method only returns licensed packages. You must provide the following query "state=unlicensed" to retrieve unlicensed packages. |
Related ONTAP commands
system license show-status -
system license show
state  |
string  |
query  |
False  |
Filter by state  |
scope  |
string  |
query  |
False  |
Filter by scope  |
name  |
string  |
query  |
False  |
Filter by name  |
licenses.serial_number  |
string  |
query  |
False  |
Filter by licenses.serial_number  |
licenses.start_time  |
string  |
query  |
False  |
Filter by licenses.start_time  |
licenses.expiry_time  |
string  |
query  |
False  |
Filter by licenses.expiry_time  |
licenses.capacity.used_size  |
integer  |
query  |
False  |
Filter by licenses.capacity.used_size  |
licenses.capacity.maximum_size  |
integer  |
query  |
False  |
Filter by licenses.capacity.maximum_size  |
licenses.compliance.state  |
string  |
query  |
False  |
Filter by licenses.compliance.state  |
licenses.evaluation  |
boolean  |
query  |
False  |
Filter by licenses.evaluation  |
licenses.active  |
boolean  |
query  |
False  |
Filter by licenses.active  |
licenses.owner  |
string  |
query  |
False  |
Filter by licenses.owner  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
max_records  |
integer  |
query  |
False  |
Limit the number of records returned.  |
return_records  |
boolean  |
query  |
False  |
return_timeout  |
integer  |
query  |
False  |
order_by  |
array[string]  |
query  |
False  |
Order results by specified fields and optional [asc  |
Status: 200, Ok
| Name | Type | Description |
_links  |
num_records  |
integer  |
Number of records  |
records  |
array[records]  |
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "licenses": [
          "capacity": {
            "maximum_size": 0,
            "used_size": 0
          "compliance": {
            "state": "compliant"
          "expiry_time": "2019-03-02T19:00:00Z",
          "owner": "cluster1",
          "serial_number": "123456789",
          "start_time": "2019-02-02T19:00:00Z"
      "name": "NFS",
      "scope": "string",
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
next  |
self  |
_links
self  |
capacity
maximum_size  |
integer  |
Licensed capacity size (in bytes) that can be used.  |
used_size  |
integer  |
Capacity that is currently used (in bytes).  |
compliance
state  |
string  |
Compliance state of the license.  |
licenses
active  |
boolean  |
A flag indicating whether the license is currently being enforced.  |
capacity  |
compliance  |
evaluation  |
boolean  |
A flag indicating whether the license is in evaluation mode.  |
expiry_time  |
string  |
Date and time when the license expires.  |
owner  |
string  |
Cluster, node or license manager that owns the license.  |
serial_number  |
string  |
Serial number of the license.  |
start_time  |
string  |
Date and time when the license starts.  |
records
_links  |
licenses  |
array[licenses]  |
Installed licenses of the package.  |
name  |
string  |
Name of the license.  |
scope  |
string  |
Scope of the license.  |
state  |
string  |
Summary state of package based on all installed licenses.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
