REST API reference
Retrieve license packages
GET /cluster/licensing/licenses
Introduced In: 9.6
Retrieves a collection of license packages.
Note By default, the GET method only returns licensed packages. You must provide the following query "state=unlicensed" to retrieve unlicensed packages. Note: Starting with ONTAP 9.11.1, the GET method no longer returns the Base license record.
  • system license show-status
entitlement.risk
string
query
False
Filter by entitlement.risk
  • Introduced in: 9.11
entitlement.action
string
query
False
Filter by entitlement.action
scope
string
query
False
Filter by scope
description
string
query
False
Filter by description
state
string
query
False
Filter by state
name
string
query
False
Filter by name
licenses.owner
string
query
False
Filter by licenses.owner
licenses.host_id
string
query
False
Filter by licenses.host_id
  • Introduced in: 9.9
licenses.active
boolean
query
False
Filter by licenses.active
licenses.expiry_time
string
query
False
Filter by licenses.expiry_time
licenses.capacity.measurement_unit
string
query
False
Filter by licenses.capacity.measurement_unit
  • Introduced in: 9.18
licenses.capacity.maximum_size
integer
query
False
Filter by licenses.capacity.maximum_size
licenses.capacity.disabled_size
integer
query
False
Filter by licenses.capacity.disabled_size
licenses.capacity.used_size
integer
query
False
Filter by licenses.capacity.used_size
licenses.serial_number
string
query
False
Filter by licenses.serial_number
licenses.evaluation
boolean
query
False
Filter by licenses.evaluation
licenses.shutdown_imminent
boolean
query
False
Filter by licenses.shutdown_imminent
licenses.start_time
string
query
False
Filter by licenses.start_time
licenses.compliance.state
string
query
False
Filter by licenses.compliance.state
licenses.installed_license
string
query
False
Filter by licenses.installed_license
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[records]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "description": "NFS License",
      "entitlement": {
        "action": "string",
        "risk": "string"
      "licenses": [
          "capacity": {
            "disabled_size": 0,
            "maximum_size": 0,
            "measurement_unit": "string",
            "used_size": 0
          "compliance": {
            "state": "compliant"
          "expiry_time": "2019-03-02 19:00:00 +0000",
          "host_id": "456-44-1234",
          "installed_license": "Core Bundle",
          "owner": "cluster1",
          "serial_number": "123456789",
          "start_time": "2019-02-02 19:00:00 +0000"
      "name": "NFS",
      "scope": "string",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
entitlement
action
string
Entitlement action to be taken to mitigate the risk
risk
string
Entitlement risk of the package
capacity
disabled_size
integer
Capacity that is currently disabled due to license limits. Its unit of measure is specified in the measurement_unit field.
maximum_size
integer
Licensed capacity size that can be used. Its unit of measure is specified in the measurement_unit field.
measurement_unit
string
Unit of measure for capacity based licenses.
used_size
integer
Specifies the total number of GPUs in the system when measurement_unit is GPUs, else specifies the bytes used.
compliance
state
string
Compliance state of the license.
licenses
active
boolean
A flag indicating whether the license is currently being enforced.
capacity
capacity
compliance
compliance
evaluation
boolean
A flag indicating whether the license is in evaluation mode.
expiry_time
string
Date and time when the license expires.
host_id
string
A string that associates the license with a node or cluster.
installed_license
string
Name of license that enabled the feature.
owner
string
Cluster, node or license manager that owns the license.
serial_number
string
Serial number of the license.
shutdown_imminent
boolean
A flag indicating whether the Cloud ONTAP system is going to shutdown as the Cloud platform license has already expired.
  • readOnly: 1
  • x-nullable: true
start_time
string
Date and time when the license starts.
records
_links
_links
description
string
License description
entitlement
entitlement
licenses
array[licenses]
Installed licenses of the package.
name
string
Name of the license.
scope
string
Scope of the license.
state
string
Summary state of package based on all installed licenses.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
