REST API reference
Retrieve all DR groups in a MetroCluster IP configuration
Retrieves all DR groups within a MetroCluster IP configuration. This is useful for monitoring and managing disaster recovery setups in your environment.
HTTP method and endpoint
GET /cluster/metrocluster/dr-groups
Introduced in
ONTAP 9.8
Usage notes
Retrieves all the DR group in the MetroCluster over IP configuration.
partner_cluster.name
string
query
False
Filter by partner_cluster.name
partner_cluster.uuid
string
query
False
Filter by partner_cluster.uuid
id
integer
query
False
Filter by id
dr_pairs.partner.uuid
string
query
False
Filter by dr_pairs.partner.uuid
dr_pairs.partner.name
string
query
False
Filter by dr_pairs.partner.name
dr_pairs.node.uuid
string
query
False
Filter by dr_pairs.node.uuid
dr_pairs.node.name
string
query
False
Filter by dr_pairs.node.name
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of Records
records
array[metrocluster_dr_group]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "dr_pairs": [
          "node": {
            "name": "node1",
          "partner": {
            "name": "node1",
      "id": 0,
      "partner_cluster": {
        "name": "cluster1",
Status: Default
ONTAP Error Response Codes
Error Code Description
2425734
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support.
2427132
MetroCluster is not configured on this cluster.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
self
node
Local node of the DR Group.
_links
_links
name
string
uuid
string
partner
Partner node of the DR Group.
_links
_links
name
string
uuid
string
dr_pair
node
node
partner
partner
ipv4_interface
Object to setup an interface along with its default router.
address
string
IPv4 or IPv6 address
gateway
string
The IPv4 or IPv6 address of the default router.
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length.
l3_config
ipv4_interface
ipv4_interface
node
Node information
_links
_links
name
string
uuid
string
mccip_ports
Port configuration specification. l3_config information is only needed when configuring a MetroCluster IP for use in a layer 3 network.
l3_config
l3_config
name
string
Port name
node
node
Node information
uuid
string
Port UUID
vlan_id
integer
VLAN ID
partner_cluster
Partner cluster information.
_links
_links
name
string
uuid
string
DR group information.
_links
self_link
dr_pairs
array[dr_pair]
id
integer
DR Group ID
partner_cluster
partner_cluster
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
