Retrieve all DR groups in a MetroCluster IP configuration
Retrieves all disaster recovery groups in a MetroCluster IP configuration to review the current state and details of these groups. This information is useful for monitoring and managing disaster recovery operations within your MetroCluster setup.
HTTP method and endpoint
GET /cluster/metrocluster/dr-groups
Introduced in
ONTAP 9.8
Usage notes
Retrieves all the DR group in the MetroCluster over IP configuration.
dr_pairs.partner.name |
string |
query |
False |
Filter by dr_pairs.partner.name |
dr_pairs.partner.uuid |
string |
query |
False |
Filter by dr_pairs.partner.uuid |
dr_pairs.node.name |
string |
query |
False |
Filter by dr_pairs.node.name |
dr_pairs.node.uuid |
string |
query |
False |
Filter by dr_pairs.node.uuid |
id |
integer |
query |
False |
Filter by id |
partner_cluster.name |
string |
query |
False |
Filter by partner_cluster.name |
partner_cluster.uuid |
string |
query |
False |
Filter by partner_cluster.uuid |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of Records |
records |
array[metrocluster_dr_group] |
"next": {
"href": "/api/resourcelink"
"records": [
"dr_pairs": [
"node": {
"name": "node1",
"partner": {
"name": "node1",
"id": 0,
"partner_cluster": {
"name": "cluster1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2425734 |
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support. |
2427132 |
MetroCluster is not configured on this cluster. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
self_link
self |
_links
self |
node
Local node of the DR Group.
_links |
name |
string |
uuid |
string |
partner
Partner node of the DR Group.
_links |
name |
string |
uuid |
string |
dr_pair
node |
Local node of the DR Group. |
partner |
Partner node of the DR Group. |
ipv4_interface
Object to setup an interface along with its default router.
address |
string |
IPv4 or IPv6 address |
gateway |
string |
The IPv4 or IPv6 address of the default router. |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length. |
l3_config
ipv4_interface |
Object to setup an interface along with its default router. |
node
Node information
_links |
name |
string |
uuid |
string |
mccip_ports
Port configuration specification. l3_config information is only needed when configuring a MetroCluster IP for use in a layer 3 network.
l3_config |
name |
string |
Port name |
node |
Node information |
uuid |
string |
Port UUID |
vlan_id |
integer |
VLAN ID |
partner_cluster
Partner cluster information.
_links |
name |
string |
uuid |
string |
DR group information.
_links |
dr_pairs |
array[dr_pair] |
id |
integer |
DR Group ID |
partner_cluster |
Partner cluster information. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
