Retrieve all DR groups in a MetroCluster IP configuration
GET /cluster/metrocluster/dr-groups
Introduced In: 9.8
Retrieves all the DR group in the MetroCluster over IP configuration.
Related ONTAP commands
metrocluster configuration-settings dr-group show
partner_cluster.name |
string |
query |
False |
Filter by partner_cluster.name |
partner_cluster.uuid |
string |
query |
False |
Filter by partner_cluster.uuid |
dr_pairs.partner.uuid |
string |
query |
False |
Filter by dr_pairs.partner.uuid |
dr_pairs.partner.name |
string |
query |
False |
Filter by dr_pairs.partner.name |
dr_pairs.node.uuid |
string |
query |
False |
Filter by dr_pairs.node.uuid |
dr_pairs.node.name |
string |
query |
False |
Filter by dr_pairs.node.name |
id |
integer |
query |
False |
Filter by id |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of Records |
records |
array[metrocluster_dr_group] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"dr_pairs": [
"node": {
"name": "node1",
"partner": {
"name": "node1",
"id": 0,
"partner_cluster": {
"name": "cluster1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2425734 |
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
self_link
self |
_links
self |
node
Local node of the DR Group.
_links |
name |
string |
uuid |
string |
partner
Partner node of the DR Group.
_links |
name |
string |
uuid |
string |
dr_pair
node |
Local node of the DR Group. |
partner |
Partner node of the DR Group. |
ipv4_interface
Object to setup an interface along with its default router.
address |
string |
IPv4 or IPv6 address |
gateway |
string |
The IPv4 or IPv6 address of the default router. |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always the netmask length. |
l3_config
ipv4_interface |
Object to setup an interface along with its default router. |
node
Node information
_links |
name |
string |
uuid |
string |
mccip_ports
Port configuration specification. l3_config information is only needed when configuring a MetroCluster IP for use in a layer 3 network.
l3_config |
name |
string |
Port name |
node |
Node information |
uuid |
string |
Port UUID |
vlan_id |
integer |
VLAN ID |
partner_cluster
Partner cluster information.
_links |
name |
string |
uuid |
string |
DR group information.
_links |
dr_pairs |
array[dr_pair] |
id |
integer |
DR Group ID |
partner_cluster |
Partner cluster information. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
