Retrieve external NTP time servers
Retrieves the collection of external NTP time servers used for time adjustment and correction. This helps ensure accurate time synchronization across your ONTAP environment.
HTTP method and endpoint
GET /cluster/ntp/servers
Introduced in
ONTAP 9.7
Usage notes
Retrieves the collection of external NTP time servers ONTAP uses for time adjustment and correction.
Related ONTAP commands
cluster time-service ntp server show
Learn more
server |
string |
query |
False |
Filter by server |
key.id |
integer |
query |
False |
Filter by key.id |
authentication_enabled |
boolean |
query |
False |
Filter by authentication_enabled |
version |
string |
query |
False |
Filter by version |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records. |
records |
array[ntp_server] |
"next": {
"href": "/api/resourcelink"
"num_records": 3,
"records": [
"authentication_enabled": 1,
"key": {
"id": 10
"server": "time.nist.gov",
"version": "auto"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
ntp_key_reference
_links |
id |
integer |
NTP symmetric authentication key identifier or index number (ID). This ID, the type of cryptographic hash, and the cryptographic hash value are all provided by the remote NTP server. |
ntp_server
_links |
boolean |
Set NTP symmetric authentication on (true) or off (false). |
key |
server |
string |
NTP server host name, IPv4, or IPv6 address. |
version |
string |
NTP protocol version for server. Valid versions are 3, 4, or auto. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
