REST API reference
Retrieve external NTP time servers
GET /cluster/ntp/servers
Introduced In: 9.7
Retrieves the collection of external NTP time servers ONTAP uses for time adjustment and correction.
  • cluster time-service ntp server show
version
string
query
False
Filter by version
server
string
query
False
Filter by server
authentication_enabled
boolean
query
False
Filter by authentication_enabled
key.id
integer
query
False
Filter by key.id
  • Max value: 65535
  • Min value: 1
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Max value: 120
  • Min value: 0
  • Default value: 15
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records.
records
array[ntp_server]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "authentication_enabled": 1,
      "key": {
        "id": 10
      "server": "time.nist.gov",
      "version": "auto"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
ntp_key_reference
_links
_links
id
integer
NTP symmetric authentication key identifier or index number (ID). This ID, the type of cryptographic hash, and the cryptographic hash value are all provided by the remote NTP server.
ntp_server
_links
_links
boolean
Set NTP symmetric authentication on (true) or off (false).
key
ntp_key_reference
server
string
NTP server host name, IPv4, or IPv6 address.
version
string
NTP protocol version for server. Valid versions are 3, 4, or auto.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
