Retrieves the collection of external ntp time servers ontap uses for time adjustment and correction
learn more
doc /cluster/ntp/servers](#docs-cluster-cluster_ntp_servers)
GET /cluster/ntp/servers
Introduced In: 9.7
Retrieves the collection of external NTP time servers ONTAP uses for time adjustment and correction.
Related ONTAP commands
cluster time-service ntp server show
Learn more
server |
string |
query |
False |
Filter by server |
version |
string |
query |
False |
Filter by version |
authentication_enabled |
boolean |
query |
False |
Filter by authentication_enabled |
key.id |
integer |
query |
False |
Filter by key.id
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records. |
records |
array[ntp_server] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"authentication_enabled": 1,
"key": {
"id": 10
"server": "time.nist.gov",
"version": "auto"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
ntp_key_reference
_links |
id |
integer |
NTP symmetric authentication key identifier or index number (ID). This ID, the type of cryptographic hash, and the cryptographic hash value are all provided by the remote NTP server. |
ntp_server
_links |
boolean |
Set NTP symmetric authentication on (true) or off (false). |
key |
server |
string |
NTP server host name, IPv4, or IPv6 address. |
version |
string |
NTP protocol version for server. Valid versions are 3, 4, or auto. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
