REST API reference
Retrieve the NIS domain and server configurations for an SVM
Retrieves the NIS domain and server configurations for a Storage Virtual Machine (SVM) to view both the domain and server settings. This information helps you understand the NIS server bindings and configurations in your network environment.
HTTP method and endpoint
GET /name-services/nis/{svm.uuid}
Introduced in
ONTAP 9.6
Usage notes
Retrieves NIS domain and server configurations of an SVM. Both NIS domain and servers are displayed by default. The bound_servers field indicates the successfully bound NIS servers.
  • vserver services name-service nis-domain show
  • vserver services name-service nis-domain show-bound
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
bound_servers
array[string]
domain
string
The NIS domain to which this configuration belongs.
servers
array[string]
A list of hostnames or IP addresses of NIS servers used by the NIS domain configuration.
svm
svm
      "href": "/api/resourcelink"
  "bound_servers": [
    "string"
  "domain": "string",
  "servers": [
    "string"
  "svm": {
    "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
