REST API reference
Retrieve the NIS domain and server configurations for an SVM
Retrieves NIS domain and server configurations for an SVM. This information helps you manage network information services settings effectively.
HTTP method and endpoint
GET /name-services/nis/{svm.uuid}
Introduced in
ONTAP 9.6
Usage notes
Retrieves NIS domain and server configurations of an SVM. Both NIS domain and servers are displayed by default. The bound_servers field indicates the successfully bound NIS servers.
  • vserver services name-service nis-domain show
  • vserver services name-service nis-domain show-bound
  • vserver services name-service nis-domain show-bound-debug
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
binding_details
array[binding_details]
An array of objects where each object represents the NIS server and it's status for a given NIS domain. It is an advanced field.
bound_servers
array[string]
domain
string
The NIS domain to which this configuration belongs.
servers
array[string]
A list of hostnames or IP addresses of NIS servers used by the NIS domain configuration.
svm
svm
      "href": "/api/resourcelink"
  "binding_details": [
      "server": "string",
      "status": {
        "code": "string",
        "message": "string"
  "bound_servers": [
    "string"
  "domain": "domainA.example.com",
  "servers": [
    "10.10.10.10",
    "example.com"
  "svm": {
    "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
binding_status
code
string
Code corresponding to the server's binding status.
message
string
Detailed description of the server's binding status.
binding_details
server
string
Hostname/IP address of the NIS server in the domain.
status
binding_status
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
