Retrieve the NIS domain and server configurations for an SVM
Retrieves NIS domain and server configurations for an SVM. This information helps you manage network information services settings effectively.
HTTP method and endpoint
GET /name-services/nis/{svm.uuid}
Introduced in
ONTAP 9.6
Usage notes
Retrieves NIS domain and server configurations of an SVM. Both NIS domain and servers are displayed by default. The bound_servers field indicates the successfully bound NIS servers.
Related ONTAP commands
vserver services name-service nis-domain show -
vserver services name-service nis-domain show-bound -
vserver services name-service nis-domain show-bound-debug
Learn more
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
binding_details |
array[binding_details] |
An array of objects where each object represents the NIS server and it's status for a given NIS domain. It is an advanced field. |
bound_servers |
array[string] |
domain |
string |
The NIS domain to which this configuration belongs. |
servers |
array[string] |
A list of hostnames or IP addresses of NIS servers used by the NIS domain configuration. |
svm |
"href": "/api/resourcelink"
"binding_details": [
"server": "string",
"status": {
"code": "string",
"message": "string"
"bound_servers": [
"string"
"domain": "string",
"servers": [
"string"
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
binding_status
code |
string |
Code corresponding to the server's binding status. |
message |
string |
Detailed description of the server's binding status. |
binding_details
server |
string |
Hostname/IP address of the NIS server in the domain. |
status |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
