Retrieve an FC WWPN alias
Retrieves an FC WWPN alias to view the specific alias configuration for Fibre Channel networks. This information helps you manage storage connectivity and zoning in your environment.
HTTP method and endpoint
GET /network/fc/wwpn-aliases/{svm.uuid}/{alias}
Introduced in
ONTAP 9.6
Related ONTAP commands
vserver fcp wwpn-alias show
Learn more
svm.uuid |
string |
path |
True |
The unique identifier of the SVM in which the alias is found. |
alias |
string |
path |
True |
The name of FC WWPN alias. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
alias |
string |
The FC WWPN alias. Required in POST. |
svm |
wwpn |
string |
The FC initiator WWPN. Required in POST. |
"href": "/api/resourcelink"
"alias": "host1",
"svm": {
"name": "svm1",
"wwpn": "2f:a0:00:a0:98:0b:56:13"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1260882 |
The supplied SVM does not exist. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
