Retrieve an FC WWPN alias
Retrieves a Fibre Channel (FC) WWPN alias to access the alias configuration associated with your network settings.
HTTP method and endpoint
GET /network/fc/wwpn-aliases/{svm.uuid}/{alias}
Introduced in
ONTAP 9.6
Usage notes
Retrieves an FC WWPN alias.
Related ONTAP commands
vserver fcp wwpn-alias show
Learn more
svm.uuid |
string |
path |
True |
The unique identifier of the SVM in which the alias is found. |
alias |
string |
path |
True |
The name of FC WWPN alias. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
alias |
string |
The FC WWPN alias. Required in POST. |
svm |
wwpn |
string |
The FC initiator WWPN. Required in POST. |
"href": "/api/resourcelink"
"alias": "host1",
"svm": {
"name": "svm1",
"wwpn": "2f:a0:00:a0:98:0b:56:13"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1260882 |
The supplied SVM does not exist. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
