REST API reference
Retrieve an FC WWPN alias
Retrieves an FC WWPN alias to view the configuration details associated with Fibre Channel networks in your setup.
HTTP method and endpoint
GET /network/fc/wwpn-aliases/{svm.uuid}/{alias}
Introduced in
ONTAP 9.6
  • vserver fcp wwpn-alias show
svm.uuid
string
path
True
The unique identifier of the SVM in which the alias is found.
alias
string
path
True
The name of FC WWPN alias.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
alias
string
The FC WWPN alias. Required in POST.
svm
svm
wwpn
string
The FC initiator WWPN. Required in POST.
      "href": "/api/resourcelink"
  "alias": "host1",
  "svm": {
    "name": "svm1",
  "wwpn": "2f:a0:00:a0:98:0b:56:13"
Status: Default
ONTAP Error Response Codes
Error Code Description
1260882
The supplied SVM does not exist.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
