REST API reference
Retrieve the CIFS domain preferred DC configuration for an SVM and domain
Accesses the CIFS domain preferred DC configuration for an SVM to view the current settings. This information is useful when managing domain controller preferences for your storage virtual machine.
HTTP method and endpoint
GET /protocols/cifs/domains/{svm.uuid}/preferred-domain-controllers/{fqdn}/{server_ip}
Introduced in
ONTAP 9.10
Usage notes
Retrieves the CIFS domain preferred DC configuration of an SVM.
  • vserver cifs domain preferred-dc show
fqdn
string
path
True
Fully Qualified Domain Name
server_ip
string
path
True
Domain Controller IP address
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
fqdn
string
Fully Qualified Domain Name.
server_ip
string
IP address of the preferred domain controller (DC). The address can be either an IPv4 or an IPv6 address.
  "fqdn": "test.com",
  "server_ip": "4.4.4.4"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
