Retrieve the CIFS domain preferred DC configuration for an SVM and domain
GET /protocols/cifs/domains/{svm.uuid}/preferred-domain-controllers/{fqdn}/{server_ip}
Introduced In: 9.10
Retrieves the CIFS domain preferred DC configuration of an SVM.
Related ONTAP commands
vserver cifs domain preferred-dc show -
vserver cifs domain preferred-dc check
fqdn |
string |
path |
True |
Fully Qualified Domain Name |
server_ip |
string |
path |
True |
Domain Controller IP address |
need_status |
boolean |
query |
False |
Retrieves the status of the specified preferred DC.
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
fqdn |
string |
Fully Qualified Domain Name. |
server_ip |
string |
IP address of the preferred domain controller (DC). The address can be either an IPv4 or an IPv6 address. |
status |
Status of CIFS preferred domain controller. |
"fqdn": "test.com",
"server_ip": "4.4.4.4",
"status": {
"details": "Response time (msec): 111",
"reachable": 1
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
status
details |
string |
Provides a detailed description of the state if the state is 'down' or the response time of the DNS server if the state is 'up'. |
reachable |
boolean |
Indicates whether or not the domain controller is reachable. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
