REST API reference
Retrieve the CIFS domain preferred DC configuration for an SVM and domain
Retrieves the CIFS domain preferred DC configuration for a specific SVM and domain to understand the preferred domain controller settings within your network.
HTTP method and endpoint
GET /protocols/cifs/domains/{svm.uuid}/preferred-domain-controllers/{fqdn}/{server_ip}
Introduced in
ONTAP 9.10
Usage notes
Retrieves the CIFS domain preferred DC configuration of an SVM.
  • vserver cifs domain preferred-dc show
  • vserver cifs domain preferred-dc check
fqdn
string
path
True
Fully Qualified Domain Name
server_ip
string
path
True
Domain Controller IP address
need_status
boolean
query
False
Retrieves the status of the specified preferred DC.
  • Introduced in: 9.12
  • Default value:
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
fqdn
string
Fully Qualified Domain Name.
server_ip
string
IP address of the preferred domain controller (DC). The address can be either an IPv4 or an IPv6 address.
status
status
Status of CIFS preferred domain controller.
svm
svm
  "fqdn": "test.com",
  "server_ip": "4.4.4.4",
  "status": {
    "details": "Response time (msec): 111",
    "reachable": 1
  "svm": {
        "href": "/api/resourcelink"
    "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
status
details
string
Provides a detailed description of the state if the state is 'down' or the response time of the DNS server if the state is 'up'.
reachable
boolean
Indicates whether or not the domain controller is reachable.
string
self
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
