Retrieve privileges for a local, or Active Directory user or group and SVM
GET /protocols/cifs/users-and-groups/privileges/{svm.uuid}/{name}
Introduced In: 9.9
Retrieves privileges of the specified local or Active Directory user or group and SVM.
Related ONTAP commands
vserver cifs users-and-groups privilege show
name  |
string  |
path  |
True  |
Local or Active Directory user or group name.  |
svm.uuid  |
string  |
path  |
True  |
UUID of the SVM to which this object belongs.  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
name  |
string  |
privileges  |
array[string]  |
An array of privileges associated with the local or Active Directory user or group. The available values are:
svm  |
      "href": "/api/resourcelink"
  "name": "user1",
  "privileges": [
    "string"
  "svm": {
    "name": "svm1",
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
