REST API reference
Retrieve privileges for a local, or Active Directory user or group and SVM
Retrieves the privileges assigned to a specified local or Active Directory user or group and SVM. Use this information to review access permissions within your storage environment.
HTTP method and endpoint
GET /protocols/cifs/users-and-groups/privileges/{svm.uuid}/{name}
Introduced in
ONTAP 9.10
Usage notes
Retrieves privileges of the specified local or Active Directory user or group and SVM.
  • vserver cifs users-and-groups privilege show
name
string
path
True
Local or Active Directory user or group name.
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
name
string
privileges
array[string]
An array of privileges associated with the local or Active Directory user or group. The available values are:
  • SeTcbPrivilege - Allows user to act as part of the operating system
  • SeBackupPrivilege - Allows user to back up files and directories, overriding any ACLs
  • SeRestorePrivilege - Allows user to restore files and directories, overriding any ACLs
  • SeTakeOwnershipPrivilege - Allows user to take ownership of files or other objects
  • SeSecurityPrivilege - Allows user to manage auditing and viewing/dumping/clearing the security log
  • SeChangeNotifyPrivilege - Allows user to bypass traverse checking
svm
svm
      "href": "/api/resourcelink"
  "name": "user1",
  "privileges": [
    "string"
  "svm": {
    "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
