Retrieve privileges for a local, or Active Directory user or group and SVM
Retrieves the privileges assigned to a specified local or Active Directory user or group and SVM. Use this information to review access permissions within your storage environment.
HTTP method and endpoint
GET /protocols/cifs/users-and-groups/privileges/{svm.uuid}/{name}
Introduced in
ONTAP 9.10
Usage notes
Retrieves privileges of the specified local or Active Directory user or group and SVM.
Related ONTAP commands
vserver cifs users-and-groups privilege show
name |
string |
path |
True |
Local or Active Directory user or group name. |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
name |
string |
privileges |
array[string] |
An array of privileges associated with the local or Active Directory user or group. The available values are:
svm |
"href": "/api/resourcelink"
"name": "user1",
"privileges": [
"string"
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
svm
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
