Retrieve the status of FPolicy servers
Retrieves the status of FPolicy servers to monitor their current operational state and configuration. This helps you ensure that file policies are enforced correctly within your network environment.
HTTP method and endpoint
GET /protocols/fpolicy/{svm.uuid}/connections
Introduced in
ONTAP 9.10
Usage notes
Retrieves the statuses of FPolicy servers.
Related ONTAP commands
vserver fpolicy show-engine -
vserver fpolicy show-passthrough-read-connection
passthrough_read |
boolean |
query |
False |
Whether to view only passthrough-read connections |
node.uuid |
string |
query |
False |
Filter by node.uuid |
node.name |
string |
query |
False |
Filter by node.name |
state |
string |
query |
False |
Filter by state |
policy.name |
string |
query |
False |
Filter by policy.name |
server |
string |
query |
False |
Filter by server |
type |
string |
query |
False |
Filter by type |
svm.name |
string |
query |
False |
Filter by svm.name |
update_time |
string |
query |
False |
Filter by update_time |
disconnected_reason.code |
integer |
query |
False |
Filter by disconnected_reason.code |
disconnected_reason.message |
string |
query |
False |
Filter by disconnected_reason.message |
session_uuid |
string |
query |
False |
Filter by session_uuid |
max_records |
integer |
query |
False |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[fpolicy_connection] |
"next": {
"href": "/api/resourcelink"
"records": [
"disconnected_reason": {
"code": 9370,
"message": "TCP Connection to FPolicy server failed."
"node": {
"name": "node1",
"policy": {
"name": "string"
"server": "10.132.145.20",
"session_uuid": "5224ec64-b336-11eb-841c-0050568e14c2",
"state": "connected",
"svm": {
"name": "svm1",
"type": "primary",
"update_time": "2019-06-12T11:00:16-04:00"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
disconnected_reason
Indicates the reason for FPolicy server disconnection.
code |
integer |
Reason ID for the FPolicy Server disconnection. |
message |
string |
FPolicy server reason for disconnection message. |
node
_links |
name |
string |
uuid |
string |
self_link
self |
fpolicy_policy_reference
_links |
name |
string |
The name of the FPolicy Policy name. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
fpolicy_connection
Displays the connection status information of the FPolicy server.
_links |
disconnected_reason |
Indicates the reason for FPolicy server disconnection. |
node |
policy |
server |
string |
IP address of the FPolicy server. |
session_uuid |
string |
Unique session ID associated with each connection to the FPolicy server and it can be used to identify the established connection. |
state |
string |
Specifies the FPolicy server connection state indicating if it is in the connected or disconnected state. The following is a list of the possible states:
svm |
type |
string |
FPolicy server type. The possible values are:
update_time |
string |
Specifies the time at which FPolicy server is connected or disconnected. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
