REST API reference
Retrieve the status of FPolicy servers
Retrieves the statuses of FPolicy servers to monitor their operational state and ensure they are functioning correctly within your network environment.
HTTP method and endpoint
GET /protocols/fpolicy/{svm.uuid}/connections
Introduced in
ONTAP 9.10
  • vserver fpolicy show-engine
  • vserver fpolicy show-passthrough-read-connection
passthrough_read
boolean
query
False
Whether to view only passthrough-read connections
update_time
string
query
False
Filter by update_time
server
string
query
False
Filter by server
disconnected_reason.code
integer
query
False
Filter by disconnected_reason.code
disconnected_reason.message
string
query
False
Filter by disconnected_reason.message
svm.name
string
query
False
Filter by svm.name
session_uuid
string
query
False
Filter by session_uuid
state
string
query
False
Filter by state
node.uuid
string
query
False
Filter by node.uuid
node.name
string
query
False
Filter by node.name
policy.name
string
query
False
Filter by policy.name
type
string
query
False
Filter by type
max_records
integer
query
False
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[fpolicy_connection]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "disconnected_reason": {
        "code": 9307,
        "message": "TCP Connection to FPolicy server failed."
      "node": {
        "name": "node1",
      "policy": {
        "name": "string"
      "server": "10.132.145.20",
      "session_uuid": "5224ec64-b336-11eb-841c-0050568e14c2",
      "state": "connected",
      "svm": {
        "name": "svm1",
      "type": "primary",
      "update_time": "2019-06-12 11:00:16 -0400"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
disconnected_reason
Indicates the reason for FPolicy server disconnection.
code
integer
Reason ID for the FPolicy Server disconnection.
message
string
FPolicy server reason for disconnection message.
node
_links
_links
name
string
uuid
string
self
fpolicy_policy_reference
_links
self_link
name
string
The name of the FPolicy Policy name.
svm
_links
_links
name
string
uuid
string
fpolicy_connection
Displays the connection status information of the FPolicy server.
_links
_links
disconnected_reason
disconnected_reason
node
node
policy
server
string
IP address of the FPolicy server.
session_uuid
string
Unique session ID associated with each connection to the FPolicy server and it can be used to identify the established connection.
state
string
Specifies the FPolicy server connection state indicating if it is in the connected or disconnected state. The following is a list of the possible states:
  • connected - Connected
  • disconnected - Disconnected
svm
svm
type
string
FPolicy server type. The possible values are:
  • primary - Primary server
  • secondary - Secondary server
update_time
string
Specifies the time at which FPolicy server is connected or disconnected.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
