Retrieve the status of FPolicy servers
Retrieves the statuses of FPolicy servers to monitor and manage their connections effectively.
HTTP method and endpoint
GET /protocols/fpolicy/{svm.uuid}/connections
Introduced in
ONTAP 9.10
Related ONTAP commands
vserver fpolicy show-engine -
vserver fpolicy show-passthrough-read-connection
passthrough_read |
boolean |
query |
False |
Whether to view only passthrough-read connections |
svm.name |
string |
query |
False |
Filter by svm.name |
policy.name |
string |
query |
False |
Filter by policy.name |
type |
string |
query |
False |
Filter by type |
update_time |
string |
query |
False |
Filter by update_time |
server |
string |
query |
False |
Filter by server |
disconnected_reason.code |
integer |
query |
False |
Filter by disconnected_reason.code |
disconnected_reason.message |
string |
query |
False |
Filter by disconnected_reason.message |
node.uuid |
string |
query |
False |
Filter by node.uuid |
node.name |
string |
query |
False |
Filter by node.name |
session_uuid |
string |
query |
False |
Filter by session_uuid |
state |
string |
query |
False |
Filter by state |
max_records |
integer |
query |
False |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[fpolicy_connection] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"disconnected_reason": {
"code": 9370,
"message": "TCP Connection to FPolicy server failed."
"node": {
"name": "node1",
"policy": {
"name": "string"
"server": "10.132.145.20",
"session_uuid": "5224ec64-b336-11eb-841c-0050568e14c2",
"state": "connected",
"svm": {
"name": "svm1",
"type": "primary",
"update_time": "2019-06-12 15:00:16 +0000"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
disconnected_reason
Indicates the reason for FPolicy server disconnection.
code |
integer |
Reason ID for the FPolicy Server disconnection. |
message |
string |
FPolicy server reason for disconnection message. |
node
_links |
name |
string |
uuid |
string |
self_link
self |
fpolicy_policy_reference
_links |
name |
string |
The name of the FPolicy Policy name. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
fpolicy_connection
Displays the connection status information of the FPolicy server.
_links |
disconnected_reason |
Indicates the reason for FPolicy server disconnection. |
node |
policy |
server |
string |
IP address of the FPolicy server. |
session_uuid |
string |
Unique session ID associated with each connection to the FPolicy server and it can be used to identify the established connection. |
state |
string |
Specifies the FPolicy server connection state indicating if it is in the connected or disconnected state. The following is a list of the possible states:
svm |
type |
string |
FPolicy server type. The possible values are:
update_time |
string |
Specifies the time at which FPolicy server is connected or disconnected. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
